xpp07
Sep 20, 2018 2:07 AM UTC
Reading a 16-bit word via SPI
In order to read a 16-bit word from a current sensor, is it correct to say:
HAL_SPI_Receive(&hspi1, &SPIRx[0], 1, 1); //?
SPIRx is declared as uint16_t SPIRx[1];
I told CubeMx that the data size for SPI1 is 16 bits
    Sep 20, 2018 3:44 AM UTC
    Probably,
    Try looking at the source for HAL_SPI_Receive() function, usually specific comments about parameters/usage.
    Seem to recall the length parameter being units of transfer size, so 1 for a single word.
    xpp07
    xpp07Author
    Sep 20, 2018 3:53 AM UTC
    I'm confused because the definition says:
    HAL_SPI_Receive(SPI_HandleTypeDef *hspi, uint8_t *pData, uint16_t Size, uint32_t Timeout),
    The second parameter uint8_t *pData, but I have the data as 16 bits. Does it affect?
    Sep 20, 2018 4:04 AM UTC
    Isn't it the same routine whether you have the SPI in 8 or 16-bit mode?
    I think (void *) would have been better for the general case, but the pointer can be recast.
    xpp07
    xpp07Author
    Sep 20, 2018 4:16 AM UTC
    If I do as above, it throws this warning:
    passing argument 2 of 'HAL_SPI_Receive' from incompatible pointer type [-Wincompatible-pointer-types]
    So, the pointer has to be 8 bits. Seems like I got my wires crossed.
