ARost.2
read 8 channels from ADC2 in regular mode
  • January 14, 2020
  • 5 replies
  • 1326 views
While I can read one channel from both ADC1 & ADC3 in injected interrupt mode, till can not find a solution to read 8 channels from ADC2 in regular mode. Please send me sample code.
ARost.2
ARost.2Author
adc2 interrupt flag is activated
adc2 triggered by timer 3 rising edge
timer 3 work good
ARost.2
ARost.2Author
HAL_ADC_Start(&hadc2);
while(1)
HAL_TIM_PeriodElapsedCallback{
if(htim->Instance == TIM3)
how to code here ?
ARost.2
ARost.2Author
/* ADC2 init function */
void MX_ADC2_Init(void)
 ADC_ChannelConfTypeDef sConfig = {0};
 /** Common config
 hadc2.Instance = ADC2;
 hadc2.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV16;
 hadc2.Init.Resolution = ADC_RESOLUTION_12B;
 hadc2.Init.ScanConvMode = ADC_SCAN_ENABLE;
 hadc2.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
 hadc2.Init.LowPowerAutoWait = DISABLE;
 hadc2.Init.ContinuousConvMode = ENABLE;
 hadc2.Init.NbrOfConversion = 8;
 hadc2.Init.DiscontinuousConvMode = DISABLE;
 hadc2.Init.ExternalTrigConv = ADC_EXTERNALTRIG_T3_TRGO;
 hadc2.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_RISING;
 hadc2.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR;
 hadc2.Init.Overrun = ADC_OVR_DATA_PRESERVED;
 hadc2.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
 hadc2.Init.OversamplingMode = DISABLE;
 if (HAL_ADC_Init(&hadc2) != HAL_OK)
   Error_Handler();
 /** Configure Regular Channel
 sConfig.Channel = ADC_CHANNEL_3;
 sConfig.Rank = ADC_REGULAR_RANK_1;
 sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
 sConfig.SingleDiff = ADC_SINGLE_ENDED;
 sConfig.OffsetNumber = ADC_OFFSET_NONE;
 sConfig.Offset = 0;
 if (HAL_ADC_ConfigChannel(&hadc2, &sConfig) != HAL_OK)
   Error_Handler();
 sConfig.Channel = ADC_CHANNEL_4;
 sConfig.Rank = ADC_REGULAR_RANK_2;
   Error_Handler();
 sConfig.Channel = ADC_CHANNEL_5;
 sConfig.Rank = ADC_REGULAR_RANK_3;
   Error_Handler();
 sConfig.Channel = ADC_CHANNEL_7;
 sConfig.Rank = ADC_REGULAR_RANK_4;
   Error_Handler();
 sConfig.Channel = ADC_CHANNEL_8;
 sConfig.Rank = ADC_REGULAR_RANK_5;
   Error_Handler();
 sConfig.Channel = ADC_CHANNEL_9;
 sConfig.Rank = ADC_REGULAR_RANK_6;
   Error_Handler();
 sConfig.Channel = ADC_CHANNEL_10;
 sConfig.Rank = ADC_REGULAR_RANK_7;
   Error_Handler();
 sConfig.Channel = ADC_CHANNEL_11;
 sConfig.Rank = ADC_REGULAR_RANK_8;
   Error_Handler();
ARost.2
ARost.2Author
how can I read 8 channels?
ARost.2
ARost.2Author
please help anybody !
