TARHAN SAMAH
Senior
Jul 30, 2018 2:16 PM UTC
RCC_CSR resgister libary not found on my cube generated project stm32f103cb
hello i try to read registers RCC_CSR with FlagStatusRCC_GetFlagStatus (uint8_t RCC_FLAG)
but my project generated by cubemx doesnt recognize this function ,
is there an option i didnt open on cube mx , or should i download a folder ,
because i couşdn find
STM32F10x Standard Peripherals Library 3.5.0 on my project
thanks
    TARHAN SAMAH
    TARHAN SAMAHBest answer
    Senior
    Aug 7, 2018 11:17 AM UTC
    thanks ,,
    i got my registers :)
    if(__HAL_RCC_GET_FLAG(RCC_FLAG_SFTRST))
    //printf("\r\n software reset");
    else if(__HAL_RCC_GET_FLAG(RCC_FLAG_PORRST))
    //printf("\r\n power reset");
    lcd_init();
    else if(__HAL_RCC_GET_FLAG(RCC_FLAG_PINRST))
      //printf("\r\n pin reset");
    else { /*printf("\r\n unknown reset ");*/  }
    //// The flags must be cleared manually after use
    __HAL_RCC_CLEAR_RESET_FLAGS();
    it works good
    Amel NASRI
    Aug 3, 2018 1:56 PM UTC
    Hi @TARHAN SAMAH​ ,
    Standard Peripheral Library isn't supported by CubeMX; It is a different development approach than the Cube.
    So, you cannot use it with CubeMX or merge code based on SPL and Cube on the same project.
    -Amel
    TARHAN SAMAH
    TARHAN SAMAHAuthorBest answer
    Senior
    thanks ,,
    lcd_init();
    it works good
