Uwe Bonnes
Chief
Nov 24, 2026 3:33 PM UTC
Rant about onlne ST32 MUC selection tool
As stmcufinder is abandoned, I tried the online tool https://www.st.com/content/st_com/en/stm32-mcu-developer-zone/mcu-portfolio.html
However e.g. the analog selection part in the top row has a  12-14-16- bit variants marked with 1 and I found no way to ask for a device with at least a 14-bit ADC. I this expected behaviour? Or what do I do wrong?
Adding the column with 16 bit ADCs in the MCU table however found many unexpected hits:
Nov 24, 2026 4:21 PM UTC
The issue is that chips without a 14- or 16- bit ADC are not marked as having 0 of them, but rather having “-” of them.
This is the same drawback with almost all peripherals. Want to find a chip with at least 1 DMMC peripheral? Can’t do it. You can search for chips with 1, and for chips with 2, but not for the range 1-2.
As a hack, you can search for chips with 2 14-bit ADCs, or 1 14-bit ADC, or 1 16 bit ADC, or 1 16-bit ADC. Not really what you want and it fails to most basic requirements of what a selection filter tool should do.
Or we both can’t figure it out.
