kroesswang_thomas
Oct 23, 2012 1:30 PM UTC
Question about USBH_BulkReceiveData() Usage
Posted on October 23, 2012 at 15:30
Hello!
I'm currently working on a project using the STM32F4 Discovery board as a CDC-Host. I have succesfully enumerated my usb device and also successfully used USBH_BulkSendData().
But now I'm unsure about how to use USBH_BulkReceiveData() correctly. Do I have to execute it before polling (HCD_GetURB_State(pdev , MSC_Machine.hc_num_in) == URB_DONE), or do I have to poll before executing the receive-handle?
When I execute USBH_BulkReceiveData() first, the STM32 goes into an infinite USB-interrupt loop. But when I poll first the URB_State always stays URB_IDLE.
I have studied the MSC Host example file but it doesn't provide an answer to my question.
    dmakhrov9
    Oct 23, 2012 2:15 PM UTC
    Posted on October 23, 2012 at 16:15
    This modified code from MSC worked for me. But that was pain. Still do not understand how it functions :)
    static USBH_Status USBH_MSC_Handle(USB_OTG_CORE_HANDLE *pdev ,
                                       void   *phost)
      USBH_HOST *pphost = phost;
      USBH_Status status = USBH_BUSY;
      uint8_t appliStatus = 0;
      uint16_t tempInt;
      if(HCD_IsDeviceConnected(pdev))
        switch(USBH_MSC_BOTXferParam.MSCState)
        case USBH_MSC_BOT_INIT_STATE:
          USBH_MSC_Init(pdev);
          USBH_MSC_BOTXferParam.MSCState = USBH_MSC_BOT_BULK;
          break;
      case USBH_MSC_BOT_BULK:
        USBH_BulkReceiveData (pdev, Buffer, 512, MSC_Machine.hc_num_in);
        USBH_MSC_BOTXferParam.MSCState = USBH_MSC_BOT_PAUSE3;
        break;
      case USBH_MSC_BOT_PAUSE3:
          if(HCD_GetURB_State(pdev , MSC_Machine.hc_num_in) == URB_DONE)
            // you stuff
              pphost->usr_cb->UserApplication(Buffer);
            USBH_MSC_BOTXferParam.MSCState = USBH_MSC_BOT_FINISH;
          break;
      case USBH_MSC_BOT_FINISH:
        break;
        case USBH_MSC_CTRL_ERROR_STATE:
          /* Issue Clearfeature request */
          status = USBH_ClrFeature(pdev,
                                   phost,
                                   0x00,
                                   pphost->Control.hc_num_out);
          if(status == USBH_OK )
            /* If GetMaxLun Request not support, assume Single LUN configuration */
            MSC_Machine.maxLun = 0;
            USBH_MSC_BOTXferParam.MSCState = USBH_MSC_BOTXferParam.MSCStateBkp;
          break;
        case USBH_MSC_BOT_USB_TRANSFERS:
          /* Process the BOT state machine */
          USBH_MSC_HandleBOTXfer(pdev , phost);
          break;
        case USBH_MSC_DEFAULT_APPLI_STATE:
          /* Process Application callback for MSC */
          appliStatus = 0;
          if(appliStatus == 0)
            USBH_MSC_BOTXferParam.MSCState = USBH_MSC_DEFAULT_APPLI_STATE;
          else if (appliStatus == 1)
            /* De-init requested from application layer */
            status =  USBH_APPLY_DEINIT;
          break;
        case USBH_MSC_UNRECOVERED_STATE:
          status = USBH_UNRECOVERED_ERROR;
          break;
        default:
          break;
       return status;
    kroesswang_thomas
    Oct 23, 2012 2:28 PM UTC
    Posted on October 23, 2012 at 16:28
    Thanks for the quick answer!
    I also used USBH_MSC_Handle to build my Statemachine.
    What I removed was USBH_MSC_Init(pdev), because as far as I know these function is only for storage devices and I don't need those.
    My Handle function looks like this: The device sends a response to the SCIP2.0 message. But I never reach case 2 because after the USBH_BulkReceiveData()-function the STM32 gets into an interrupt loop.
                                       void   *phost)
      uint8_t mscStatus = USBH_MSC_BUSY;
      uint8_t scip20 [8] = {'S','C','I','P','2','.','0',0x0A};
      uint8_t scip_BM [3] = {'B','M',0x0A};
      uint8_t scip_QT [3] = {'Q','T',0x0A};
        static uint8_t answer [40];
        static uint8_t urb_status;
        switch(cdc_state)
                urb_status = HCD_GetURB_State(pdev , MSC_Machine.hc_num_out);
                if(urb_status != URB_NOTREADY)
          USBH_BulkSendData (pdev,
                                                    &scip20[0],
                                                    7 ,
                cdc_state = 1;
                //USB_OTG_BSP_mDelay(100);
          break;
            case 1:
                if(urb_status == URB_DONE)
                                answer,
                        USBH_MSC_MPS_SIZE ,
                    cdc_state = 2;
                break;
                case 2:
                                                    &scip_QT[0],
                                                    3 ,
                    cdc_state = 3;
                break;
        default:
          break;
       return status;
    dmakhrov9
    Oct 23, 2012 3:32 PM UTC
    Posted on October 23, 2012 at 17:32
    I believed I understood C-language before I looked at ST's USB host stack. To me, it is a switch-case-function-pointer massacre :)
