AMend.7
QUADSPI examples using OCTOSPI peripheral
Is there any example of how to interface a NOR FLASH QUADSPI memory using the OCTOSPI interface used in the H72x, U5 or H5?
KDJEM.1
KDJEM.1Best answer
Hello @AMend.7​ ,
To configurate QUADSPI using OCTOSPI peripheral, I recommend you to take a look to AN5050 and precisely 6.2 OCTOSPI configuration with STM32CubeMX Section .
In the mentioned application note, you need to refer to the tables "STM32CubeMX - Configuration of OCTOSPI signals and mode" and look deeply to the provided examples.
I Hope this help you!
Kaouthar
May 9, 2023
I built an example on the NUCLEO-H723 if you're looking for a consult.​
KDJEM.1
KDJEM.1Best answer
Hello @AMend.7​ ,
Kaouthar
