PWM+DMA to Generate a pulse output with a controlled number and adjustable duty cycle
I‘m configuring the timer pwm+dma output with cubemx, and I want to get a pulse output with a controlled number and adjustable duty cycle. and I used the above three methods, only the last two valid, but not the normal output.
