amass.9
Programming header and Debug Header for STM32L073 micro?
I am laying out  aboard with STM32L073. I would like to add a debug header and a programming header. Do you know which pins i should connect  these headers to?
I see that PA13 and PA14 are involved in debugging, but which other pins do i also need to include in the header?
April 6, 2025
VCC and GND
NRST to allow for controlled startup
On CM3,4,7 consider PB3 / SWO, but not supported on CM0(+) parts
amass.9
amass.9Author
Thanks, by CM3, CM4, CM7, do you mean the Cortex-M thing?
How would i know if i have a CM3 say?
The part number is
STM32L073CBU6 (LQFP48)
Andrew Neil
It would certainly be stated in the datasheet.
Most likely even in the marketing material; eg,
https://www.st.com/en/microcontrollers-microprocessors/stm32l0-series.html
STM32L0 is Cortex-M0+
