Snm.1
Programlama pinleriinin ekstra özellikleri.
Bir projemde stm32l052 kullanmaktayım ve işlemci pin sayım yetersiz gelmekte. Acaba programlama pinlerini programlama yapmıyorken gpio olarak kullanabilirmiyim?
Hello @Snm.1​ and welcome to the Community :)
Please try to write in English if you want to get an answer, because most of the people on this community can speak English but not Turc.
I used Google translate to get an rough idea of what you are saying :
"Extra features of programming pins.
I am using stm32l052 in a project and my processor pin count is insufficient. I wonder if I can use the programming pins as gpio when not programming?
You have the possibility to use the GPIO and select alternate functions inputs/outputs. You should check the GPIO pins in the datasheet of your product.
Imen
