patrickbuchbauer9
Jun 10, 2009 7:09 AM UTC
Problems with the NVIC / Interrupt priority
Posted on June 10, 2009 at 09:09
    patrickbuchbauer9
    May 17, 2011 11:14 AM UTC
    Posted on May 17, 2011 at 13:14
    I'm working with the STM32F103VBT6. In my application I have to run a motor and communicate with another controller over the USART1 interface.
    Everything for its own works fine. But when I received data over the interface and the motor is running at that time, the motor stops after some characters. When I run the motor at higher speed, it stops faster.
    So this looks like there is a conflict between the interrupts.
    So I have changed the NVIC_PriorityGroupConfig for the USART1 and also the NVIC_IRQChannelPreemptionPriority, but without success.
    The ohter interrupts are triggered by the TIM1.
    Can someone help me, thanks in advance.
    Patrick
    artur2
    Setting of the NVIC_PriorityGroupConfig does not change interrupt priority (at least not directly).
    First you should configure interrupt priority grouping (using NVIC_PriorityGroupConfig) then set priorities for your peripherals (using NVIC_Init).
    See folder Project/Examples/NVIC/Priority in the stm32f10x standard peripheral library.
    Regards,
