problems with interrupts in stm32 - timer interrupts and external interrupts
  • January 15, 2024
  • 5 replies
  • 2247 views
i have an issue with my timer interrupt that every 500 us happends and external interrupts (12EXTI) .
when the timer interrupt happend , the external interrupts never execute.
i dont know why this is happening.
i mean it supposed to pending for other interrupts but it looks like this is not happening
    LCE
    Principal II
    January 15, 2024
    Let me guess... oops, not possible without further info. ;)
    So please:
    - which STM32?
    - show some relevant source code (interrupt enable, priorities, handlers)
    stm32f446
    void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
    // Set the counter value to zero
    htim3.Instance->CNT = 0;
    n2 = 0;
    HAL_ADC_Start(&hadc2);
    HAL_ADC_Start(&hadc3);
    if (HAL_ADC_PollForConversion(&hadc2, 1000) == HAL_OK)
    adc_value2 = HAL_ADC_GetValue(&hadc2);
    if (HAL_ADC_PollForConversion(&hadc3, 1000) == HAL_OK)
    adc_value3 = HAL_ADC_GetValue(&hadc3);
    if( adc_value3 > data_max )
    n2 = 1;
    adc_value3 = adc_value2 ;
    if(n2 == 0)
    adc_value3 = adc_value3/2 ;
    //Filter Part
    data_dac = ( 2.3/3 )* data;
    HAL_DAC_SetValue(&hdac, DAC_CHANNEL_1, DAC_ALIGN_12B_R, data_dac);
    if (data <= ( limitPercentage1 * data_max ) )
    if ( ( HAL_GPIO_ReadPin(GPIOB, RELAY_GPIO_PIN) == GPIO_PIN_RESET ) && ( HAL_GPIO_ReadPin(GPIOB, GPIO_PIN_4) == GPIO_PIN_SET ) )
    //ON RELAY
    HAL_GPIO_WritePin(GPIOB, RELAY_GPIO_PIN, GPIO_PIN_SET); //A0
    //OFF RED LED
    HAL_GPIO_WritePin(GPIOB, LED_GPIO_PIN, GPIO_PIN_RESET);
    //Give permission to operator to reset micro
    HAL_GPIO_WritePin(GPIOB , GPIO_PIN_5 , GPIO_PIN_SET); //A1
    else
    //HAL_Delay( lowestDelay1 * 1000 );
    //Turn off Relay
    HAL_GPIO_WritePin(GPIOB, RELAY_GPIO_PIN, GPIO_PIN_RESET); //A0
    //ON RED LED
    HAL_GPIO_WritePin(GPIOB, LED_GPIO_PIN, GPIO_PIN_SET);
    //Get permission off operator to reset micro
    HAL_GPIO_WritePin(GPIOB , GPIO_PIN_5 , GPIO_PIN_RESET);
    void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
    /* Prevent unused argument(s) compilation warning */
    UNUSED(GPIO_Pin);
    while(keyOk < 3 )
    lowestDelay = 0;
    setGain = 0;
    gainStatus = 0;
    if (HAL_GPIO_ReadPin(GPIOC, GAIN_CONTROL_PIN_1) == GPIO_PIN_SET) {
    gainStatus++;
    setGain = 10;
    else if (HAL_GPIO_ReadPin(GPIOB, GAIN_CONTROL_PIN_2) == GPIO_PIN_SET) {
    gainStatus++;
    setGain = 25;
    else if (HAL_GPIO_ReadPin(GPIOC, GAIN_CONTROL_PIN_3) == GPIO_PIN_SET) {
    gainStatus++;
    setGain = 50;
    else if (HAL_GPIO_ReadPin(GPIOC, GAIN_CONTROL_PIN_4) == GPIO_PIN_SET) {
    gainStatus++;
    setGain = 100;
    else {
    setGain = 300;
    // Check if at least two GPIOs are set to 1
    if (gainStatus < 2)
    keyOk++;
    setGain = setGain ;
    if((keyOk > 2) & (n == 0))
    keyOk = 2;
    else
    keyOk--;
    if(keyOk < 0)
    keyOk = 0 ;
    // Calculate the delay percentage based on the active switches
    limitPercentage = 0;
    if (HAL_GPIO_ReadPin(GPIOC, LIMIT_CONTROL_PIN_1)== GPIO_PIN_SET)
    limitPercentage += 10;
    if (HAL_GPIO_ReadPin(GPIOC, LIMIT_CONTROL_PIN_2)== GPIO_PIN_SET)
    limitPercentage += 20;
    if (HAL_GPIO_ReadPin(GPIOA, LIMIT_CONTROL_PIN_3)== GPIO_PIN_SET)
    limitPercentage += 40;
    if (HAL_GPIO_ReadPin(GPIOA, LIMIT_CONTROL_PIN_4)== GPIO_PIN_SET)
    limitPercentage += 80;
    // Check if the sum exceeds 90%
    if (limitPercentage <= 90)
    keyOk++;
    limitPercentage = limitPercentage ;
    keyOk = 2;
    else
    keyOk--;
    if(keyOk < 0)
    keyOk = 0 ;
    if (HAL_GPIO_ReadPin(GPIOA, DELAY_CONTROL_PIN_1)== GPIO_PIN_SET ) lowestDelay = 1;
    if (HAL_GPIO_ReadPin(GPIOA, DELAY_CONTROL_PIN_2)== GPIO_PIN_SET ) lowestDelay = (lowestDelay == 0) ? 2 : lowestDelay;
    if (HAL_GPIO_ReadPin(GPIOB, DELAY_CONTROL_PIN_3)== GPIO_PIN_SET ) lowestDelay = (lowestDelay == 0) ? 4 : ((lowestDelay < 4) ? lowestDelay : 4);
    if (HAL_GPIO_ReadPin(GPIOB, DELAY_CONTROL_PIN_4)== GPIO_PIN_SET ) lowestDelay = (lowestDelay == 0) ? 8 : ((lowestDelay < 8) ? lowestDelay : 8);
    if ( keyOk == 2)
    keyOk = 1;
    n = 1;
    else if ( keyOk < 2)
    keyOk = 0 ;
    keyOk = 2 ;
    //Set potentiometer Based on GPIO That connect by DIP switches
    // Set the MCP41010 resistance to 3.7 kohms (0x70).
    MCP41010_SetResistance(&hspi1, 0x70);
    // Set the MCP41010 resistance to 5 kohms (0xA0).
    MCP41010_SetResistance(&hspi1, 0xA0);
    // Set the MCP41010 resistance to 7 kohms (0xD0).
    MCP41010_SetResistance(&hspi1, 0xD0);
    // Set the MCP41010 resistance to 8.5 kohms (0xF0).
    MCP41010_SetResistance(&hspi1, 0xF0);
    limitPercentage1 = limitPercentage ;
    lowestDelay1 = lowestDelay ;
    HAL_ADC_Start(&hadc1);
    if (HAL_ADC_PollForConversion(&hadc2, 1000) == HAL_OK) {
    //m1 = HAL_ADC_GetValue(&hadc2);
    HAL_GPIO_WritePin(GPIOB , GPIO_PIN_7 , GPIO_PIN_SET); // A3
    //HAL_Delay(5);
    while(1)
    //m2 = HAL_ADC_GetValue(&hadc2);
    //HAL_Delay(5);
    if ( m2 > m1 )
    m1 = m2;
    n1 = 0;
    else
    n1++;
    if (n1>=2)
    // Read the value of setGain and Compare the range of m1 for each value
    if(setGain == 10)
    if( ( 100 < m1 ) && ( m1 < 200 ) )
    //HAL_TIM_Base_Start_IT(&htim3);
    break;
    else
    HAL_GPIO_WritePin(GPIOB , GPIO_PIN_8 , GPIO_PIN_SET); //RESET MICRO USING MAX6962
    if(setGain == 25)
    if( ( 100 < m1 ) & ( m1 < 200 ) )
    break;
    else
    if(setGain == 50)
    break;
    else
    if(setGain == 100)
    break;
    else
    if(setGain == 300)
    break;
    else
    // 3 times toggle LED
    for (int q=0;q<60000;q++);
    //HAL_Delay(300);
    for (int q=0;q<60000;q++) ;
    //HAL_Delay(300);
    // HAL_Delay(300);
    // HAL_Delay(300);
    // HAL_Delay(300);
    static void MX_TIM3_Init(void)
    /* USER CODE BEGIN TIM3_Init 0 */
    /* USER CODE END TIM3_Init 0 */
    TIM_ClockConfigTypeDef sClockSourceConfig = {0};
    TIM_MasterConfigTypeDef sMasterConfig = {0};
    /* USER CODE BEGIN TIM3_Init 1 */
    /* USER CODE END TIM3_Init 1 */
    htim3.Instance = TIM3;
    htim3.Init.Prescaler = 1000-1;
    htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
    htim3.Init.Period = 45-1;
    htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
    htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
    if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
    Error_Handler();
    sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
    if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
    sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
    sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
    if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
    Error_Handler();
    HAL_NVIC_SetPriority(TIM3_IRQn, 0 , 0);
    HAL_NVIC_EnableIRQ(TIM3_IRQn);
    /* USER CODE BEGIN TIM3_Init 2 */
    /* USER CODE END TIM3_Init 2 */
    static void MX_GPIO_Init(void)
    /* USER CODE BEGIN MX_GPIO_Init_1 */
    /* USER CODE END MX_GPIO_Init_1 */
    /* GPIO Ports Clock Enable */
    __HAL_RCC_GPIOH_CLK_ENABLE();
    __HAL_RCC_GPIOC_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    __HAL_RCC_GPIOB_CLK_ENABLE();
    __HAL_RCC_GPIOD_CLK_ENABLE();
    /*Configure GPIO pin Output Level */
    HAL_GPIO_WritePin(GPIOC, GPIO_PIN_11|GPIO_PIN_12, GPIO_PIN_RESET);
    HAL_GPIO_WritePin(GPIOD, GPIO_PIN_2, GPIO_PIN_RESET);
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_3|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7, GPIO_PIN_RESET);
    /*Configure GPIO pins : PC3 PC4 PC5 */
    GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5;
    GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING_FALLING;
    GPIO_InitStruct.Pull = GPIO_PULLDOWN;
    HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
    /*Configure GPIO pins : PB1 PB2 PB13 PB14
    PB15 */
    GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_13|GPIO_PIN_14
    |GPIO_PIN_15;
    /*Configure GPIO pins : PA9 PA10 PA11 PA12 */
    GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12;
    /*Configure GPIO pins : PC11 PC12 */
    GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12;
    /*Configure GPIO pin : PD2 */
    GPIO_InitStruct.Pin = GPIO_PIN_2;
    HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
    /*Configure GPIO pins : PB3 PB5 PB6 PB7 */
    GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7;
    /*Configure GPIO pin : PB4 */
    GPIO_InitStruct.Pin = GPIO_PIN_4;
    GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
    /* EXTI interrupt init*/
    HAL_NVIC_SetPriority(EXTI1_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(EXTI1_IRQn);
    HAL_NVIC_SetPriority(EXTI2_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(EXTI2_IRQn);
    HAL_NVIC_SetPriority(EXTI3_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(EXTI3_IRQn);
    HAL_NVIC_SetPriority(EXTI4_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(EXTI4_IRQn);
    HAL_NVIC_SetPriority(EXTI9_5_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(EXTI9_5_IRQn);
    HAL_NVIC_SetPriority(EXTI15_10_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);
    /* USER CODE BEGIN MX_GPIO_Init_2 */
    /* USER CODE END MX_GPIO_Init_2 */
    LCE
    Principal II
    January 15, 2024
    There is this nice little forum option "</>" for source code input, which is unfortunately hidden in the 2nd row, so first click this "...", then you see "</>".
    Otherwise the code is not readable that well. And please only post what might actually be needed.
    Here's the NVIc Config for External interrupts
    Here's The Callback Function for Timer 3 interrupt:
    void
    n2 = 0;
    //if (HAL_ADC_PollForConversion(&hadc2, 1000) == HAL_OK)
    //if (HAL_ADC_PollForConversion(&hadc3, 1000) == HAL_OK)
    n2 = 1;
    if(n2 == 0)
    //Filter Part
    //ON RELAY
    //OFF RED LED
    else
    //Turn off Relay
    //ON RED LED
    Here's Timer3 Config:
    htim3
    .Instance = TIM3;
    htim3.Init.Period = 9000-1;
    Error_Handler();
    Error_Handler();
    Error_Handler();
