Problem with STM32g070 ADC
I got a problem with STM32G070RBTx ADC configuration. I configured ADC in interrupt mode. After each conversion I change channel to measure different pin.
I got 9 pins to measure(PA0 - PA7 and PB12). With PINS on PORTA I got no problem but PB12 is problematic. According to datasheet it is connected to ADC1_IN16, but configuring Channel as ADC_CHANNEL_16 measure PA0 instead of PB12.
Here is the function to change channels in adc:
void config_ext_channel_ADC(uint32_t channel)
ADC_ChannelConfTypeDef sConfig = {0};
switch(channel)
case 0:
sConfig.Channel = ADC_CHANNEL_0;
break;
case 1:
sConfig.Channel = ADC_CHANNEL_1;
break;
case 2:
sConfig.Channel = ADC_CHANNEL_2;
break;
case 3:
sConfig.Channel = ADC_CHANNEL_3;
break;
case 4:
sConfig.Channel = ADC_CHANNEL_4;
break;
case 5:
sConfig.Channel = ADC_CHANNEL_5;
break;
case 6:
sConfig.Channel = ADC_CHANNEL_6;
break;
case 7:
sConfig.Channel = ADC_CHANNEL_7;
break;
case 8:
sConfig.Channel = ADC_CHANNEL_16;
break;
case 9:
sConfig.Channel = ADC_CHANNEL_TEMPSENSOR;
break;
case 10:
sConfig.Channel = ADC_CHANNEL_VBAT;
break;
case 11:
sConfig.Channel = ADC_CHANNEL_VREFINT;
break;
sConfig.Rank = ADC_REGULAR_RANK_1;
sConfig.SamplingTime = ADC_SAMPLINGTIME_COMMON_1;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
}What am I doing wrong?
Thanks in advance
