juozas
Problem with STM32F746 : EXTI15_10_IRQ is constantly fired
  • March 29, 2018
  • 760 views
Posted on March 29, 2018 at 13:55
Hi, today I have observed and solved a problem when I started to develop my simple program for NUCLEO-F746ZG. A problem  was following: EXTI15_10_IRQHandler interrupt fired always - regardless of my changes in program. By observing system register SYSCFG content in my debugger, I have found, that content of SYSCFG always is zero, regardless of executing of the line LL_SYSCFG_SetEXTISource(LL_SYSCFG_EXTI_PORTC, LL_SYSCFG_EXTI_LINE13);
My code was generated by newest CubeMX with my selection USE_FULL_LL_DRIVER (without Ethernet and without USB support) and manually ported to Embitz. I have found solution - to add a line LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_SYSCFG);
Interestingly - why CubeMX do not add this line!
Best regards.
    Posted on March 30, 2018 at 11:47
    Hello
    Kimtys.Juozas
    Thank you for reported this issue.
    This issue is raised internally for check and investigation.
    Best Regards,
    Imen
    Nawres GHARBI
    Posted on May 03, 2018 at 16:05
    Hi
    Kimtys.Juozas
    This issue will be fixed next release 4.0 of MX.
    enjoy using MX
