kurtn
Problem with ST example - NVIC - IRQ_Channels
  • July 19, 2010
  • 4 replies
  • 1014 views
Posted on July 19, 2010 at 20:14
#debug #cortex
kurtn
kurtnAuthor
Posted on May 17, 2011 at 13:59
Has anyone some suggestions or ideas, please?
jpeacock23
Look at the Cortex HFSR register when you get the hard fault.  That will give you a clue as to what the problem may be.  If it is a ''precise'' error then the return address on the stack will be the fault location.
Chances are it's a coding bug, bad pointer address or something similar.
  Jack Peacock
kurtn
kurtnAuthor
It seems, that problem´s solved. The fault was between keyboard and chair. I tried to add the startup file to the project and it worked. Some examples don´t require the adding the startup file, but some examples require it. That´s strange.
kurtn
kurtnAuthor
Thank you for your reply, I will check it.
