ngtbinh
Problem with internal sram
  • May 27, 2016
  • 4 replies
  • 1119 views
Posted on May 27, 2016 at 06:12
I'm just starting with cortex-m3 and with gnu arm toolchain
Myquestion may be stupid
Because the internal SRAM in the Cortex-m3 is 64KB max,when i build project is keil ver 4 it can not compiler. My project is declare more variable array so it not enough when use internal sram
How to config for keil will use external sram when build project ?
Many thanks
    May 27, 2016
    Posted on May 27, 2016 at 10:48
    As previously established the CM3 is not limited to 64KB of IRAM. In Keil you can define memory regions available in the Target options pane.
    You will need to add code into SystemInit to configure your external memory pins and FSMC settings.
    ngtbinh
    ngtbinhAuthor
    Posted on May 30, 2016 at 03:20
    Thanks clive1,
    You can give me document or link for that?
    I don't know how to do this
    Many thanks
    ngtbinh
    ngtbinhAuthor
    Posted on May 30, 2016 at 04:38
    Thanks clive1,
    I use STM32F10
    Many thanks
