TBaue.1
Apr 21, 2020 8:19 AM UTC
Problem with ADC DMA One Shot Mode
Hi folks,
i'm using a STM32H750 MCU for analog data acquisition.
I've implemented a simple UART Command interface to trigger a measurement with a given number of samples. This Interface works fine (checked it with the debugger).
Now the Problem: only the first measurement after Reset seems to work. My structure to take a measurement of x samples is setup as follows:
  • UART RX Interrupt checkes incomming command and triggers the measurement
  • ADC_Start (only aimed, waiting for ext. interrupt via GPIO)
  • HAL_DMA_START
  • GPIO Gets triggered
  • ...idle... (sampling in progress, DMA shifts the data)
  • DMA-Transfer-Complete IT fires and calls "USR_sampling_done" function
  • ADC_Stop and transfer of samples via UART
When sending the next measure command, nothing happens. With the Debugger i've found out, that the HAL_DMA_Start function does not "reinit" the DMA. It returns from "__HAL_LOCK()" (Line 24) since the DMA Instance seems to still be locked. What is the Problem here? I thought that the DMA_IRQ_Handler takes care of clearing all the IT-Flags and "frees" the DMA Instance. I further checked the HAL functions for DMA and could not found any function that manually stops odr reinit the DMA.
Now some code for better understanding:
 * @brief Starts the DMA Transfer.
 * @param hdma : pointer to a DMA_HandleTypeDef structure that contains
 * the configuration information for the specified DMA Stream.
 * @param SrcAddress: The source memory Buffer address
 * @param DstAddress: The destination memory Buffer address
 * @param DataLength: The length of data to be transferred from source to destination
 * @retval HAL status
HAL_StatusTypeDef HAL_DMA_Start(DMA_HandleTypeDef *hdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t DataLength)
 HAL_StatusTypeDef status = HAL_OK;
 /* Check the parameters */
 assert_param(IS_DMA_BUFFER_SIZE(DataLength));
 /* Check the DMA peripheral handle */
 if(hdma == NULL)
 return HAL_ERROR;
 /* Process locked */
 __HAL_LOCK(hdma);
 if(HAL_DMA_STATE_READY == hdma->State)
 /* Change DMA peripheral state */
 hdma->State = HAL_DMA_STATE_BUSY;
 /* Initialize the error code */
 hdma->ErrorCode = HAL_DMA_ERROR_NONE;
 /* Disable the peripheral */
 __HAL_DMA_DISABLE(hdma);
 /* Configure the source, destination address and the data length */
 DMA_SetConfig(hdma, SrcAddress, DstAddress, DataLength);
 /* Enable the Peripheral */
 __HAL_DMA_ENABLE(hdma);
 else
 /* Process unlocked */
 __HAL_UNLOCK(hdma);
 /* Set the error code to busy */
 hdma->ErrorCode = HAL_DMA_ERROR_BUSY;
 /* Return error status */
 status = HAL_ERROR;
 return status;
void USR_sampling_done()
	uint16_t i = 0;
	uint16_t nos = usr_ctrl_inst.num_of_samples/2;
	uint32_t *pSample;
	uint16_t helper = 0;
	pSample = &samples[0];
	HAL_ADC_Stop(&hadc1);
	HAL_GPIO_WritePin(PLL_TRIG_PORT, PLL_TRIG_PIN, GPIO_PIN_RESET);
	while (i < nos)
		helper = *pSample & 0xFFFF;
		USR_printf_val(helper);
		helper = *pSample >> 16;
		pSample++;
		i++;
/* Start single Measurement */
		 if(usr_ctrl_inst._f_ctrl & _F_MEAS_TRIG)
			 usr_ctrl_inst._f_ctrl &= ~(_F_MEAS_TRIG);
			 /* Aim the ADC and the DMA for Conversion of given number of samples */
			 HAL_DMA_Start(&hdma_adc1, (uint32_t)&(hadc1.Instance->DR), (uint32_t)&samples[0], usr_ctrl_inst.num_of_samples );
			 HAL_ADC_Start(&hadc1);
			 /* One Shot the ADC after short Delay (which not necessary) */
			 HAL_Delay(500);
			 HAL_GPIO_WritePin(PLL_TRIG_PORT, PLL_TRIG_PIN, GPIO_PIN_SET);
 * @brief This function handles DMA1 stream0 global interrupt.
void DMA1_Stream0_IRQHandler(void)
 /* USER CODE BEGIN DMA1_Stream0_IRQn 0 */
 /* USER CODE END DMA1_Stream0_IRQn 0 */
 HAL_DMA_IRQHandler(&hdma_adc1);
 /* USER CODE BEGIN DMA1_Stream0_IRQn 1 */
 USR_sampling_done();
 /* USER CODE END DMA1_Stream0_IRQn 1 */
Thanks in advance, and let me know if something is missing :)
Regards!
Tony
