Pablito Parseval
Feb 3, 2018 3:11 PM UTC
Problem to set ADC Channell
Posted on February 03, 2018 at 16:11
Hi all,
i'm working with a STM32L053 processor and I'm having some trouble managing the ADC.
My ADC is setup to work in discontinuous mode, so i set the channel to convert by using the
following function:
void systemConfig_SetupTemperatureChannel(void)
   ADC_ChannelConfTypeDef sConfig;
   /**Configure for the selected ADC regular channel to be converted.
   sConfig.Channel = ADC_CHANNEL_4;
   sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
   if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
      _Error_Handler(__FILE__, __LINE__);
void systemConfig_ResetTemperatureChannel(void)
   sConfig.Rank = ADC_RANK_NONE;
void systemConfig_SetupReferenceVoltageChannel(void)
   sConfig.Channel = ADC_CHANNEL_5;
void systemConfig_ResetReferenceVoltageChannel(void)
   sConfig.Rank =
ADC_RANK_NONE
The function are called in the main loop like there:
main()
systemConfig_SetupTemperatureChannel();
   /* Get value */
   HAL_ADC_Start_DMA(&hadc, vectorPointerA, sampleNumber);
   HAL_Delay(1000);
   /* Reset Temp Channell */
systemConfig_
Reset
   /* Set  Voltage Ref Channell*/
   systemConfig_SetupReferenceVoltageChannel();
    /* Get value */
   HAL_ADC_Start_DMA(&hadc, vectorPointerB, sampleNumber);
    /*Reset Reference Channel*/
systemConfig_
Reset
   HAL_Delay(1000);
Now if i debug step by step all the conversion are made perfectly in the correct channell.
Istead if the program run, the channell 5 is not set correctly and set to 0. I test that with a
breakpoin to the row :
and loocking the recister of the channell selection that is set to 0.
Can anyone help?
