Problem loading STM32WB5MM RTC prescalers
I have used STM32CubeMX to change the prescalers in the STM32_WPAN section. However, the code itself never uses the new values. It appears that “something” has marked the RTC as already initialized and it won’t execute that code.
How can I force my code to load the new values?
Nite: The values that are being loaded came from when I enabled the BLE code, but it causes the RTC to run too slow.
