Ash G
Jun 19, 2018 11:45 PM UTC
Printf SWO debugging in Cortex M0+
Posted on June 20, 2018 at 01:45
I'm trying to use printf to SWO viewer on ST-LINK utility for debugging purposes. I'm using a STM32L062K8, which has a Cortex M0+processor. After much research on the internet, found out that ITM trace is not available on M0+ processors. Which means I can't use any ITM functions as explained
http://www.openstm32.org/forumthread2893
. I can't find any solution or tutorial on this problem. Is there any work around for this situation?
Thank you!
    Tesla DeLoreanBest answer
    Jun 20, 2018 2:55 AM UTC
    Posted on June 20, 2018 at 02:55
    https://community.st.com/0D70X000006SlaWSAS
    Jun 19, 2018 11:54 PM UTC
    Posted on June 20, 2018 at 01:54
    Bob Boys published an article on using the EVT event recorder method. I'll try to dig up the posts when I get back to a computer.
    Ash G
    Ash GAuthor
    Jun 20, 2018 3:34 AM UTC
    Posted on June 20, 2018 at 03:34
    Thank you! Appreciate your help. But unfortunately, I'm using STM32 Workbench. I have come a long way with this project to change IDE now. Is there any other solution available that will work with STM32 Workbench?
