an_it
Nov 15, 2012 4:01 PM UTC
Power-On Reset from Code?
Posted on November 15, 2012 at 17:01
Hey Folks,
I know it is possible to reset processor with NVIC_SystemReset(). However, is it possible to enforce a _full_ power-off -> power-on reset from inside the code?
Cheers
    Nov 15, 2012 5:31 PM UTC
    Posted on November 15, 2012 at 18:31
    Well probably not in the sense you want, but you could use a GPIO pin to suppress an external regulator, or loop back to -RESET
    STANDBY turns off some internal regulators, and exits via a reset.
    But basically if you want the supply to go away, you'll have to make it really go away.
