harinath
Jun 1, 2012 8:59 AM UTC
Power management circuit for STM32F103
Posted on June 01, 2012 at 10:59
Dear all,
I need to design a board based on STM32F103RE.
My board need to be powered in two ways, USB & Li-Ion 3.7V battery. In addition i need to design a IN-BUILT battery charging circuit( USB to Li-Ion battery) for the board. When I attach battery, it should be automatically charged and kept in this state until the other power source (USB or external adapter) is removed and it should AUTOMATICALLY power the board - no jumpers, no switches!
I found the exact functional power_supply section in the following board schematics:
OLIMEXINO-STM32 MAPLE / ARDUINO LIKE DEVELOPMENT BOARD
http://www.olimex.com/dev/DUINO/OLIMEXINO-STM32/OLIMEXINO-STM32.pdf
http://www.olimex.com/dev/DUINO/OLIMEXINO-STM32/OLIMEXINO-STM32_Rev_B.pdf
This  board has 3 power supply options. I need only two of them.
I also have iNEMO v2 Board from ST Microelectronics :
http://www.st.com/internet/evalboard/product/250367.jsp
It has two power supply options, but a switch is used to select one of them. Moreover, it needs 5V DC supply if USB power not used.
In my case i want to use 3.7 Li-Ion/Li-Po battery when USB not used. I did not like the switch to select power source.
I liked auto switching power source of
If it is possible to just remove the DC-DC power supply(power input voltage from 9 to 30V DC) part of OLIMEXINO-STM32 it really suits me.
But i need to use SMD components to make my board as small as possible, like iNEMO v2.
I would like to request if you have any suggestions for me or
If you think you can solve my problem in few minutes & send circuit diagram, i will be very thankful.
Below are the power management circuits of two boards i mentioned:
http://dl.dropbox.com/u/14046521/Power_management.png
http://dl.dropbox.com/u/14046521/iNEMO_STM32.png
Thank you.
#stm32-power-management
    darla14
    Sep 17, 2015 11:53 AM UTC
    Posted on September 17, 2015 at 13:53
    HI,
    Did you suceed in implementing this?Any pointers to the folks here.
    Sep 17, 2015 8:29 PM UTC
    Posted on September 17, 2015 at 22:29
    We used an LTC4062
    http://www.linear.com/product/LTC4062
