davidle.ee9
Apr 6, 2019 9:23 PM UTC
Please share or let me know what is the best solution for a long timer ( 2 to 4 Hours) interrupt example(s)
I want to set up the interrupt for system power off the main MCU, the STM32L4 xx .
As soon it is powered on, then starting the timer to turn it off after 2- to- 4 Hours.
Please point me how to implement it since I'm still new for STM32L4xx
S.Ma
Principal
Apr 7, 2019 5:17 AM UTC
You probably have to look at RTC with alarms as the duration required here is quite long.
Otherwise, use the LPTIM which should have its own clock local source
davidle.ee9
Apr 7, 2019 7:32 AM UTC
But I'm in using its internal RC as the system clock (no external X-tal )
Could it be OK for your idea?
S.Ma
Principal
Apr 7, 2019 12:55 PM UTC
On stm32l4 most peripherals can run with their own chosen clock source... For optimum power saving. Checkout the LPTIMER
Peter Mather
Apr 7, 2019 7:42 AM UTC
the 32-bit Timer2 with a 16-bit prescaler set will easily meet your requirement
