damien2399
Jan 23, 2012 3:04 PM UTC
Play wav sound from SD Card STM32F2xx
Posted on January 23, 2012 at 16:04
I want to play wav files from an SDCard with my STM32F2xx.
I used SDIO example and I added FatFs support on it and it's OK.
Next, I tried to use STM audio example to play audio from memory, and it's work (first I had a problem with I2C and I fixed it).
Those two examples work fine but, when I want to add SD support on audio example, SD don't work anymore, and when I add audio on SD example, audio don't work ...
Maybe someone already tried this on a STM32F2xx.
Thanks.
    akshaya
    Mar 8, 2012 1:37 PM UTC
    Posted on March 08, 2012 at 14:37
    Hi Damien
    Were you able to achieve playout of wave through SD Card. I am trying the same on an STM32F4XX but I am facing problems.
    My playout is start-stop and not continuous. Let me know if you were successful.
    holger
    Aug 21, 2012 9:38 AM UTC
    Posted on August 21, 2012 at 11:38
    Hi damien,
    have you solved your SDIO+I2C problem?
    Why this question?
    I've problems reading the SDCard, while using a touchscreen I/O interface, that uses I2C.
    Best regards,
    Holger
