deepak
Aug 21, 2014 8:02 AM UTC
PID PROBLEM IN CONTROLLER STM 32
Posted on August 21, 2014 at 10:02
i am facing problem for the PiD controller.
what parameter i have to use it for the positive & negative nos for calculation purpose.
Kindly look following code
New_Duty_cycle_buck=(Previous_Duty_cycle_buck + Error_Duty_cycle_buck);
where ''Error_Duty_cycle_buck'' can be positive or negative.
it is for the updating a new duty cycle.
in declaration part,
double Error_Duty_cycle_buck=0;
i declare like this.
but my pid loop not working correctly.
pls help
Look forward to hearing you soon.
#stm32f4 #discovery
frankmeyer9
Aug 21, 2014 2:50 PM UTC
Posted on August 21, 2014 at 16:50
That is more of a P controller algorithm with kP=1, and not PID.
...but my pid loop not working correctly.
Hard to judge, you did not present any 'pid loop' code.
Aug 21, 2014 4:54 PM UTC
Posted on August 21, 2014 at 18:54
Not very good at explaining problems. [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Problem%20in%20duty%20cycle&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&currentviews=38]https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2Fcortex_mx_stm32%2FProblem%20in%20duty%20cycle&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=38
Do the math, print out the results to the console, and also try with PC based C code emulating the loop and the values you expect to read. Once you have modeled it correctly apply it to hardware, and the value read there.
