tifou
December 10, 2013
periphe
  • December 10, 2013
  • 671 views
Posted on December 10, 2013 at 12:32
heloo,
I have problem ?
how to use
the null-modem female/female RS232 cable between the DB9 connectr CN16 (USART3) and PC serial ??can you give me a picture please ?
#lmgtfy #first-principles #ask-better-questions
    Andrew Neil
    Posted on December 10, 2013 at 13:47
    Google for the PC pinout;
    Look at the board schematic for the board pinout;
    Take care to understand which are inputs and which are outputs (don't just assume that ''RX'' means input - it doesn't necessarily);
    You should be able to take it from there...
    December 10, 2013
    Posted on December 10, 2013 at 15:20
    STM324x9I-EVAL board?
    Just connect them together?
    http://www.cablesforless.com/DB9-Female-Female-Null-Modem-Cables-C345.aspx
    should work. Pin out if you're interested
    http://www.aggsoft.com/rs232-pinout-cable/nullmodem-db9-to-db9.htm
