xinghua
Aug 4, 2009 8:15 AM UTC
Performance of Running Code in External RAM
Posted on August 04, 2009 at 10:15
    ivanov-i
    May 17, 2011 10:54 AM UTC
    Posted on May 17, 2011 at 12:54
    The external memory is not a good place for running a code for STM32. As AN2784 states the minimum access latency for the external memory is 3 cycles for half a word even if you put no delays in the configuration register (Figure 6).
    In addition, the external memory is connected to D-bus, which means that there will be more delays waiting for data transfers over the same bus.
    xinghua
    xinghuaAuthor
    We are using High Density Series STM32 chip. The embedded SRAM is up to 64KB. We try running code from external SRAM, and it seems extremely ''slow''.
    I am wondering how the performance will be like if running linux, considering normally linux kernel is large (over several hundred KBytes) and copied from a stroage device(flash) to RAM, and then wholly running in RAM.
