PB6 not working when debugging
I am using PB6 as a GPIO input with a pull-up for monitoring a switch to ground. It works properly when not debugging but has some kind of signal on it when debugging that prevents proper operation. Note: I am using the STLINK-V3SET debugger.
Is there a way that I can disable whatever is causing this?
