KYang.7
May 21, 2021 2:09 PM UTC
OS install error
I just got a stm32L475 Iot Kit.
And after compilation, I got this error .
st-flash 1.7.0-23-ga9adf9c
2021-05-21T22:17:24 INFO common.c: L4xx: 96 KiB SRAM, 1024 KiB flash in at least 2 KiB pages.
open(./BUILD/DISCO_L475VG_IOT01A/GCC_ARM/thingsboard-l475vg-iot01a.bin) == -1
2021-05-21T22:17:24 ERROR common.c: map_file() == -1
stlink_fwrite_flash() == -1
I don't know what this means.
Please tell me what I did wrong.
Thank you
KYang.7
KYang.7Best answer
Jun 1, 2021 6:15 AM UTC
Thank you for your answer of my question.
But never mind it, I already make it.
I compiled them on mbed online compiler on windows 10 and I copied a .bin file to my board.
It worked very goo.
Thank you anyway.
Kwansoo
Amel NASRI
May 31, 2021 4:18 PM UTC
Hi @KYang.7​ ,
  • which example are you trying to compile?
  • what are you using as compiler?
-Amel
KYang.7
KYang.7AuthorBest answer
It worked very goo.
Thank you anyway.
Kwansoo
Amel NASRI
Jun 1, 2021 10:24 AM UTC
Glad to know that all is working fine for you, @KYang.7​ .
-Amel
