sholojda
Jun 5, 2023 5:48 AM UTC
NVIC and Piority Grouping in STM32 after reset
Hi.
I have in my hand Nucleo with STM32F103 (old uC but to understand grouping newer is not needed).
In Programming Manual PM0056 on page 134 and 135 I can see a SC_AIRCR register which on PRIGROUP field at reset are all zeros, but on next page in table 45 Piority grouping PRIGROUP [2:0] walues that can be written into this filds are only b011, b100, b101, b110 and b111.
How to undestand this?
Danish1
Lead III
Jun 5, 2023 11:27 AM UTC
My guess is that this error in documentation was only spotted (and fixed) on more modern versions of the manual. For example PM0214 Rev 8 (stm32f4) shows 0b0xx gives group priority bits 7:4, not just 0b011
Jun 5, 2023 11:37 AM UTC
Check ARM TRM or simply print them out to confirm.
Expect they reset to zero, but shouldn't be hard to determine or to set to what you actually want / need.​
sholojda
sholojdaAuthor
Jun 5, 2023 12:09 PM UTC
I have read ARM TRM and according to that if PRIGROUP is b000 number of pre-emptition piorities should be 128 and 2 subprorities but STM32 has only 16 levels so there is something wrong?!
Pavel A.
Jun 5, 2023 1:00 PM UTC
"Implementations having fewer than 8-bits of interrupt priority treat the least significant bits as zero."
STM32's have 4 bits of interrupt priority which gives at most 16 preemption levels, 0-15 and no sub-priorities. This is the default mode of ST HAL library.
You can select less than 4 bits of preemption then remaining bits will be used for sub-priority.
Many ST examples use priority value 0 or (0, 0) - it will work with any PRIGROUP value, valid or not, even all zeros.
Piranha
Principal III
Jun 6, 2023 9:28 PM UTC
The default reset value already makes all 16 levels as group (preemption) priorities. Just do not change it...
