Nucleo H7S34L8 ADC Configuration
I am very heravily struggling setting up my ADC in continmous conversion mode with HPDMA with multipkle channels.
The DMA seems to stay idle, while the SFRs are saying the ADC is running.
Is there a issue in the config of the ADCs?
/* USER CODE BEGIN Header */
 * @file adc.c
 * @brief This file provides code for the configuration
 * of the ADC instances.
 * @attention
 * Copyright (c) 2025 STMicroelectronics.
 * All rights reserved.
/* USER CODE END Header */
#include "adc.h"
/* USER CODE BEGIN 0 */
#include <stdint.h>
/* USER CODE END 0 */
ADC_HandleTypeDef hadc1;
ADC_HandleTypeDef hadc2;
DMA_NodeTypeDef Node_HPDMA1_Channel0;
DMA_QListTypeDef List_HPDMA1_Channel0;
DMA_HandleTypeDef handle_HPDMA1_Channel0;
DMA_NodeTypeDef Node_HPDMA1_Channel1;
DMA_QListTypeDef List_HPDMA1_Channel1;
DMA_HandleTypeDef handle_HPDMA1_Channel1;
/* ADC1 init function */
void MX_ADC1_Init(void)
 /* USER CODE BEGIN ADC1_Init 0 */
 /* USER CODE END ADC1_Init 0 */
 ADC_MultiModeTypeDef multimode = {0};
 ADC_ChannelConfTypeDef sConfig = {0};
 /* USER CODE BEGIN ADC1_Init 1 */
 /* USER CODE END ADC1_Init 1 */
 /** Common config
 hadc1.Instance = ADC1;
 hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV10;
 hadc1.Init.Resolution = ADC_RESOLUTION_12B;
 hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
 hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
 hadc1.Init.EOCSelection = ADC_EOC_SEQ_CONV;
 hadc1.Init.LowPowerAutoWait = DISABLE;
 hadc1.Init.ContinuousConvMode = ENABLE;
 hadc1.Init.NbrOfConversion = 7;
 hadc1.Init.DiscontinuousConvMode = DISABLE;
 hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
 hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
 hadc1.Init.SamplingMode = ADC_SAMPLING_MODE_NORMAL;
 hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR;
 hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
 hadc1.Init.OversamplingMode = DISABLE;
 if (HAL_ADC_Init(&hadc1) != HAL_OK)
 Error_Handler();
 /** Configure the ADC multi-mode
 multimode.Mode = ADC_MODE_INDEPENDENT;
 if (HAL_ADCEx_MultiModeConfigChannel(&hadc1, &multimode) != HAL_OK)
 Error_Handler();
 /** Configure Regular Channel
 sConfig.Channel = ADC_CHANNEL_0;
 sConfig.Rank = ADC_REGULAR_RANK_1;
 sConfig.SamplingTime = ADC_SAMPLETIME_92CYCLES_5;
 sConfig.SingleDiff = ADC_SINGLE_ENDED;
 sConfig.OffsetNumber = ADC_OFFSET_NONE;
 sConfig.Offset = 0;
 sConfig.OffsetSign = ADC_OFFSET_SIGN_NEGATIVE;
 if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_3;
 sConfig.Rank = ADC_REGULAR_RANK_2;
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_5;
 sConfig.Rank = ADC_REGULAR_RANK_3;
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_6;
 sConfig.Rank = ADC_REGULAR_RANK_4;
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_9;
 sConfig.Rank = ADC_REGULAR_RANK_5;
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_10;
 sConfig.Rank = ADC_REGULAR_RANK_6;
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_18;
 sConfig.Rank = ADC_REGULAR_RANK_7;
 Error_Handler();
 /* USER CODE BEGIN ADC1_Init 2 */
 /* USER CODE END ADC1_Init 2 */
/* ADC2 init function */
void MX_ADC2_Init(void)
 /* USER CODE BEGIN ADC2_Init 0 */
 /* USER CODE END ADC2_Init 0 */
 /* USER CODE BEGIN ADC2_Init 1 */
 /* USER CODE END ADC2_Init 1 */
 /** Common config
 hadc2.Instance = ADC2;
 hadc2.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV10;
 hadc2.Init.Resolution = ADC_RESOLUTION_12B;
 hadc2.Init.DataAlign = ADC_DATAALIGN_RIGHT;
 hadc2.Init.ScanConvMode = ADC_SCAN_ENABLE;
 hadc2.Init.EOCSelection = ADC_EOC_SEQ_CONV;
 hadc2.Init.LowPowerAutoWait = DISABLE;
 hadc2.Init.ContinuousConvMode = ENABLE;
 hadc2.Init.NbrOfConversion = 7;
 hadc2.Init.DiscontinuousConvMode = DISABLE;
 hadc2.Init.ExternalTrigConv = ADC_SOFTWARE_START;
 hadc2.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
 hadc2.Init.SamplingMode = ADC_SAMPLING_MODE_NORMAL;
 hadc2.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR;
 hadc2.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
 hadc2.Init.OversamplingMode = DISABLE;
 if (HAL_ADC_Init(&hadc2) != HAL_OK)
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_1;
 sConfig.Offset = 0;
 if (HAL_ADC_ConfigChannel(&hadc2, &sConfig) != HAL_OK)
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_2;
 Error_Handler();
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_12;
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_13;
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_15;
 Error_Handler();
 Error_Handler();
 /* USER CODE BEGIN ADC2_Init 2 */
 /* USER CODE END ADC2_Init 2 */
static uint32_t HAL_RCC_ADC12_CLK_ENABLED=0;
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
 DMA_NodeConfTypeDef NodeConfig= {0};
 RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
 if(adcHandle->Instance==ADC1)
 /* USER CODE BEGIN ADC1_MspInit 0 */
 /* USER CODE END ADC1_MspInit 0 */
 /** Initializes the peripherals clock
 PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC;
 PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_PLL2P;
 if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
 Error_Handler();
 /* ADC1 clock enable */
 HAL_RCC_ADC12_CLK_ENABLED++;
 if(HAL_RCC_ADC12_CLK_ENABLED==1){
 __HAL_RCC_ADC12_CLK_ENABLE();
 __HAL_RCC_GPIOC_CLK_ENABLE();
 __HAL_RCC_GPIOA_CLK_ENABLE();
 __HAL_RCC_GPIOB_CLK_ENABLE();
 __HAL_RCC_GPIOF_CLK_ENABLE();
 /**ADC1 GPIO Configuration
 PC0 ------> ADC1_INP10
 PA0 ------> ADC1_INP0
 PA4 ------> ADC1_INP18
 PA6 ------> ADC1_INP3
 PB0 ------> ADC1_INP9
 PB1 ------> ADC1_INP5
 PF12 ------> ADC1_INP6
 GPIO_InitStruct.Pin = GPIO_PIN_0;
 GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
 HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
 GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_4|GPIO_PIN_6;
 GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1;
 GPIO_InitStruct.Pin = GPIO_PIN_12;
 HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
 /* ADC1 DMA Init */
 /* HPDMA1_REQUEST_ADC1 Init */
 NodeConfig.NodeType = DMA_HPDMA_LINEAR_NODE;
 NodeConfig.Init.Request = HPDMA1_REQUEST_ADC1;
 NodeConfig.Init.BlkHWRequest = DMA_BREQ_SINGLE_BURST;
 NodeConfig.Init.Direction = DMA_PERIPH_TO_MEMORY;
 NodeConfig.Init.SrcInc = DMA_SINC_FIXED;
 NodeConfig.Init.DestInc = DMA_DINC_INCREMENTED;
 NodeConfig.Init.SrcDataWidth = DMA_SRC_DATAWIDTH_HALFWORD;
 NodeConfig.Init.DestDataWidth = DMA_DEST_DATAWIDTH_HALFWORD;
 NodeConfig.Init.SrcBurstLength = 1;
 NodeConfig.Init.DestBurstLength = 1;
 NodeConfig.Init.TransferAllocatedPort = DMA_SRC_ALLOCATED_PORT1|DMA_DEST_ALLOCATED_PORT0;
 NodeConfig.Init.TransferEventMode = DMA_TCEM_BLOCK_TRANSFER;
 NodeConfig.Init.Mode = DMA_NORMAL;
 NodeConfig.TriggerConfig.TriggerPolarity = DMA_TRIG_POLARITY_MASKED;
 NodeConfig.DataHandlingConfig.DataExchange = DMA_EXCHANGE_NONE;
 NodeConfig.DataHandlingConfig.DataAlignment = DMA_DATA_PACK;
 if (HAL_DMAEx_List_BuildNode(&NodeConfig, &Node_HPDMA1_Channel0) != HAL_OK)
 Error_Handler();
 if (HAL_DMAEx_List_InsertNode(&List_HPDMA1_Channel0, NULL, &Node_HPDMA1_Channel0) != HAL_OK)
 Error_Handler();
 if (HAL_DMAEx_List_SetCircularMode(&List_HPDMA1_Channel0) != HAL_OK)
 Error_Handler();
 handle_HPDMA1_Channel0.Instance = HPDMA1_Channel0;
 handle_HPDMA1_Channel0.InitLinkedList.Priority = DMA_LOW_PRIORITY_LOW_WEIGHT;
 handle_HPDMA1_Channel0.InitLinkedList.LinkStepMode = DMA_LSM_FULL_EXECUTION;
 handle_HPDMA1_Channel0.InitLinkedList.LinkAllocatedPort = DMA_LINK_ALLOCATED_PORT0;
 handle_HPDMA1_Channel0.InitLinkedList.TransferEventMode = DMA_TCEM_BLOCK_TRANSFER;
 handle_HPDMA1_Channel0.InitLinkedList.LinkedListMode = DMA_LINKEDLIST_CIRCULAR;
 if (HAL_DMAEx_List_Init(&handle_HPDMA1_Channel0) != HAL_OK)
 Error_Handler();
 if (HAL_DMAEx_List_LinkQ(&handle_HPDMA1_Channel0, &List_HPDMA1_Channel0) != HAL_OK)
 Error_Handler();
 __HAL_LINKDMA(adcHandle, DMA_Handle, handle_HPDMA1_Channel0);
 if (HAL_DMA_ConfigChannelAttributes(&handle_HPDMA1_Channel0, DMA_CHANNEL_NPRIV) != HAL_OK)
 Error_Handler();
 /* USER CODE BEGIN ADC1_MspInit 1 */
 /* USER CODE END ADC1_MspInit 1 */
 else if(adcHandle->Instance==ADC2)
 /* USER CODE BEGIN ADC2_MspInit 0 */
 /* USER CODE END ADC2_MspInit 0 */
 Error_Handler();
 /* ADC2 clock enable */
 /**ADC2 GPIO Configuration
 PC2 ------> ADC2_INP12
 PC3 ------> ADC2_INP13
 PA1 ------> ADC2_INP1
 PA3 ------> ADC2_INP15
 PA5 ------> ADC2_INP18
 PF13 ------> ADC2_INP2
 PF14 ------> ADC2_INP6
 GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3;
 GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_3|GPIO_PIN_5;
 GPIO_InitStruct.Pin = GPIO_PIN_13|GPIO_PIN_14;
 /* ADC2 DMA Init */
 /* HPDMA1_REQUEST_ADC2 Init */
 NodeConfig.Init.Request = HPDMA1_REQUEST_ADC2;
 if (HAL_DMAEx_List_BuildNode(&NodeConfig, &Node_HPDMA1_Channel1) != HAL_OK)
 Error_Handler();
 if (HAL_DMAEx_List_InsertNode(&List_HPDMA1_Channel1, NULL, &Node_HPDMA1_Channel1) != HAL_OK)
 Error_Handler();
 if (HAL_DMAEx_List_SetCircularMode(&List_HPDMA1_Channel1) != HAL_OK)
 Error_Handler();
 handle_HPDMA1_Channel1.Instance = HPDMA1_Channel1;
 handle_HPDMA1_Channel1.InitLinkedList.Priority = DMA_LOW_PRIORITY_LOW_WEIGHT;
 handle_HPDMA1_Channel1.InitLinkedList.LinkStepMode = DMA_LSM_FULL_EXECUTION;
 handle_HPDMA1_Channel1.InitLinkedList.LinkAllocatedPort = DMA_LINK_ALLOCATED_PORT0;
 handle_HPDMA1_Channel1.InitLinkedList.TransferEventMode = DMA_TCEM_BLOCK_TRANSFER;
 handle_HPDMA1_Channel1.InitLinkedList.LinkedListMode = DMA_LINKEDLIST_CIRCULAR;
 if (HAL_DMAEx_List_Init(&handle_HPDMA1_Channel1) != HAL_OK)
 Error_Handler();
 if (HAL_DMAEx_List_LinkQ(&handle_HPDMA1_Channel1, &List_HPDMA1_Channel1) != HAL_OK)
 Error_Handler();
 __HAL_LINKDMA(adcHandle, DMA_Handle, handle_HPDMA1_Channel1);
 if (HAL_DMA_ConfigChannelAttributes(&handle_HPDMA1_Channel1, DMA_CHANNEL_NPRIV) != HAL_OK)
 Error_Handler();
 /* USER CODE BEGIN ADC2_MspInit 1 */
 /* USER CODE END ADC2_MspInit 1 */
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
 /* USER CODE BEGIN ADC1_MspDeInit 0 */
 /* USER CODE END ADC1_MspDeInit 0 */
 /* Peripheral clock disable */
 HAL_RCC_ADC12_CLK_ENABLED--;
 if(HAL_RCC_ADC12_CLK_ENABLED==0){
 __HAL_RCC_ADC12_CLK_DISABLE();
 HAL_GPIO_DeInit(GPIOC, GPIO_PIN_0);
 HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0|GPIO_PIN_4|GPIO_PIN_6);
 HAL_GPIO_DeInit(GPIOB, GPIO_PIN_0|GPIO_PIN_1);
 HAL_GPIO_DeInit(GPIOF, GPIO_PIN_12);
 /* ADC1 DMA DeInit */
 HAL_DMA_DeInit(adcHandle->DMA_Handle);
 /* ADC1 interrupt Deinit */
 /* USER CODE BEGIN ADC1:ADC1_2_IRQn disable */
 * Uncomment the line below to disable the "ADC1_2_IRQn" interrupt
 * Be aware, disabling shared interrupt may affect other IPs
 /* HAL_NVIC_DisableIRQ(ADC1_2_IRQn); */
 /* USER CODE END ADC1:ADC1_2_IRQn disable */
 /* USER CODE BEGIN ADC1_MspDeInit 1 */
 /* USER CODE END ADC1_MspDeInit 1 */
 /* USER CODE BEGIN ADC2_MspDeInit 0 */
 /* USER CODE END ADC2_MspDeInit 0 */
 HAL_GPIO_DeInit(GPIOC, GPIO_PIN_2|GPIO_PIN_3);
 HAL_GPIO_DeInit(GPIOA, GPIO_PIN_1|GPIO_PIN_3|GPIO_PIN_5);
 HAL_GPIO_DeInit(GPIOF, GPIO_PIN_13|GPIO_PIN_14);
 /* ADC2 DMA DeInit */
 /* ADC2 interrupt Deinit */
 /* USER CODE BEGIN ADC2:ADC1_2_IRQn disable */
 /* USER CODE END ADC2:ADC1_2_IRQn disable */
 /* USER CODE BEGIN ADC2_MspDeInit 1 */
 /* USER CODE END ADC2_MspDeInit 1 */
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
Thanks so much for yourt help!
Best regards//
There's nothing wrong in the code you've shared.
You haven't shared any code which actually starts the ADC.
VidarAuthor
My bad, i appllied the relevant files.
The ADCs get started by the dma_testbench.c
This is the linker file of the project in the appli context:
** @file : LinkerScript.ld
** Target : STM32H7Sxx (NUCLEO-H7S3L8)
** Flash : XIP, memory-mapped at 0x70000000
** RAM_D2 : Fully reserved for non-cacheable DMA buffers
ENTRY(Reset_Handler)
/* End of AXI SRAM used for stack */
_estack = ORIGIN(RAM) + LENGTH(RAM);
_Min_Heap_Size = 0x200;
_Min_Stack_Size = 0x400;
/* Memory map */
MEMORY
 /* External / XIP Flash */
 FLASH (rx) : ORIGIN = 0x70000000, LENGTH = 262144K
 ITCM (xrw) : ORIGIN = 0x00000000, LENGTH = 64K
 DTCM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K
 RAM_D3 (xrw) : ORIGIN = 0x38800000, LENGTH = 4K
 /* Entire D2 SRAM used as non-cacheable buffer pool */
 RAM_D2 (xrw) : ORIGIN = 0x30000000, LENGTH = 32K
 /* AXI SRAM */
 RAM (xrw) : ORIGIN = 0x24000000, LENGTH = 384K
/* Sections */
SECTIONS
 /* Vector table */
 .isr_vector :
 . = ALIGN(4);
 KEEP(*(.isr_vector))
 . = ALIGN(4);
 } >FLASH
 /* Code */
 .text :
 . = ALIGN(4);
 *(.text)
 *(.text*)
 *(.glue_7)
 *(.glue_7t)
 *(.eh_frame)
 KEEP (*(.init))
 KEEP (*(.fini))
 . = ALIGN(4);
 _etext = .;
 } >FLASH
 /* Read-only data */
 .rodata :
 . = ALIGN(4);
 *(.rodata)
 *(.rodata*)
 . = ALIGN(4);
 } >FLASH
 .ARM.extab (READONLY) :
 . = ALIGN(4);
 *(.ARM.extab* .gnu.linkonce.armextab.*)
 . = ALIGN(4);
 } >FLASH
 .ARM (READONLY) :
 . = ALIGN(4);
 __exidx_start = .;
 *(.ARM.exidx*)
 __exidx_end = .;
 . = ALIGN(4);
 } >FLASH
 .preinit_array (READONLY) :
 . = ALIGN(4);
 PROVIDE_HIDDEN (__preinit_array_start = .);
 KEEP (*(.preinit_array*))
 PROVIDE_HIDDEN (__preinit_array_end = .);
 . = ALIGN(4);
 } >FLASH
 .init_array (READONLY) :
 . = ALIGN(4);
 PROVIDE_HIDDEN (__init_array_start = .);
 KEEP (*(SORT(.init_array.*)))
 KEEP (*(.init_array*))
 PROVIDE_HIDDEN (__init_array_end = .);
 . = ALIGN(4);
 } >FLASH
 .fini_array (READONLY) :
 . = ALIGN(4);
 PROVIDE_HIDDEN (__fini_array_start = .);
 KEEP (*(SORT(.fini_array.*)))
 KEEP (*(.fini_array*))
 PROVIDE_HIDDEN (__fini_array_end = .);
 . = ALIGN(4);
 } >FLASH
 _sidata = LOADADDR(.data);
 /* Initialized data */
 .data :
 . = ALIGN(4);
 _sdata = .;
 *(.data)
 *(.data*)
 *(.RamFunc)
 *(.RamFunc*)
 . = ALIGN(4);
 _edata = .;
 } >RAM AT> FLASH
 /* Non-cacheable DMA buffers in RAM_D2 */
 .noncacheable (NOLOAD) :
 . = ALIGN(32);
 __NONCACHEABLEBUFFER_BEGIN = .;
 *(.noncacheable_buffer)
 *(.noncacheable_buffer*)
 . = ALIGN(32);
 __NONCACHEABLEBUFFER_END = .;
 } >RAM_D2
 /* BSS */
 .bss :
 . = ALIGN(4);
 _sbss = .;
 __bss_start__ = _sbss;
 *(.bss)
 *(.bss*)
 *(COMMON)
 . = ALIGN(4);
 _ebss = .;
 __bss_end__ = _ebss;
 } >RAM
 /* Heap and stack */
 ._user_heap_stack :
 . = ALIGN(8);
 PROVIDE ( end = . );
 PROVIDE ( _end = . );
 . = . + _Min_Heap_Size;
 . = . + _Min_Stack_Size;
 . = ALIGN(8);
 } >RAM
 /DISCARD/ :
 libc.a ( * )
 libm.a ( * )
 libgcc.a ( * )
 .ARM.attributes 0 : { *(.ARM.attributes) }
 /* Optional ITCM section */
 .ITCM :
 . = ALIGN(4);
 KEEP (*(.ITCM))
 . = ALIGN(4);
 } >ITCM
 /* Optional RAM_D3 section */
 .RAM_D3 :
 . = ALIGN(4);
 KEEP (*(.RAM_D3))
 . = ALIGN(4);
 } >RAM_D3
 Thanks for the help!
