Kurt Harders
February 19, 2018
NUCLEO-F767ZI x-nucleo connectors
Posted on February 19, 2018 at 19:08
I would like to use the mentioned nucleo board and compine it with an x-nucleo-ips02 board. When comparing the pinouts i did not find corresponding pins on the connectors. Is the necleo-144-board incompatible the the connectors of the x-nucleo shields?
Kind regards, Kurt
    John Craven
    Senior
    February 19, 2018
    Posted on February 19, 2018 at 19:43
    All nucleo boards accept Arduino UNO R3 shields, which is the connector format on you nuc shield.
