Sep 5, 2025 4:04 AM UTC
NOR Flash on OSPI bus with ST MX25UM51245G Library
Hello, I am struggling to use the following ST library for a project I am working on, I am using an stm32u5 with an MX25UM51245G NOR chip connected to the OSPI1 bus.  The library provided is setup to use XSPI_HandleTypeDef, Can this library be used when using the OSPI bus?
ST MX25UM51245G Library on github
Thank you
KDJEM.1
KDJEM.1Best answer
Sep 8, 2025 1:12 PM UTC
Hello @brohr01 ,
Yes, you can use XSPI_HandleTypeDef with STM32U5.
I recommend you to look at the main.c for OSPI_NOR_MemoryMapped example and get inspired. This example use XSPI_HandleTypeDef with OCTOSPI interface:
XSPI_HandleTypeDef OSPIHandle;
I hope this answer you request.
Thank you.
Kaouthar
KDJEM.1
KDJEM.1Best answer
Hello @brohr01 ,
Thank you.
Kaouthar
KDJEM.1
Sep 26, 2025 3:42 PM UTC
Hello @brohr01 ;
Is my reply answered your request?
If yes, please click on Accept as Solution on the reply which answered your question.
Thank you.
Kaouthar
