ZLu.1
May 25, 2020 11:39 AM UTC
No matter how long the power on reset time is, the MCU can not start normally. The reset button must be pressed manually once to start. Why?
PDesh.1
May 25, 2020 12:03 PM UTC
Hi ZLu.1
This is because Boot0 pin might be floating. Hence on every power on processor enters boot mode & to pressing reset switch takes it out of boot mode.
To overcome this issue, Tie it Boot0 to Gnd through 10K resistor as suggested in datasheet, this will takes CPU in run mode on every power on.
May 25, 2020 12:50 PM UTC
What STM32 part, wired how?
