need to have time separate from main loop_stm32f407
Posted on September 19, 2014 at 15:30
hi every body
in my program i need to do somethings in specific time , this ''time'' is not equal all the time.for example for doing first job i need to do it 5 sec after a flag become set. and after that i need to make it zero and after that doing second job when this timer is more than 3secthis timer has not stop ever . it has to count separately from the any other part of cpu.and it should be as much accurate as counting milisecond.note in this case i cant use Systick because i using it for something else.thanks in advance
