Jim Seymour
Senior
May 31, 2018 5:43 PM UTC
Need help getting EXTI0 Wakeup interrupt (on STM32F042)
Posted on May 31, 2018 at 19:43
I'm using CubeMX and don't see a way to enable the EXTI0 IRQ.  I'm assuming I need to have that interrupt enabled in order to use the PA0 pin as a wakeup pin.
I've set that pin to SYS_WKUP1 in the pin configuration.  What else do I need to do?
Thanks.
    Jim Seymour
    Jim SeymourBest answer
    Senior
    May 31, 2018 10:30 PM UTC
    Posted on June 01, 2018 at 00:30
    OK.  Nevermind.  I got it working - thanks to this page:
    https://www.waveshare.com/wiki/STM32CubeMX_Tutorial_Series:_EXTI
    It turns out I needed to set the pin in CubeMX to 'GPIO_EXTI0' - not 'SYS_WKUP1'.  Once I did that, the IRQ magically appeared and now my code successfully sleeps and wakes up.
    Jim Seymour
    Senior
    May 31, 2018 10:04 PM UTC
    Posted on June 01, 2018 at 00:04
    I guess my real question is: How do I enable PA0 to be SYS_WKUP1?  And what code do I have to include in my app?  I could find no examples.
    Thanks.
    Jim Seymour
    Jim SeymourAuthorBest answer
    Senior
