alexlu.29
Multi channel ADC
  • November 5, 2009
  • 4 replies
  • 867 views
Posted on November 05, 2009 at 16:19
Multi channel ADC
    alexlu.29
    alexlu.29Author
    Posted on May 17, 2011 at 13:29
    I use STM32F103T4 for voltage monitoring. I need all 10 channels. I modified an ADC example from the lib, please see the code below:
    #define ADC1_DR_Address ((vu32) 0x4001244C)
    ADC_InitTypeDef ADC_InitStructure;
    DMA_InitTypeDef DMA_InitStructure;
    vu16 ADC_ConvertedValue[10];
    /* DMA Channel1 Configuration ----------------------------------------------*/
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
    DMA_InitStructure.DMA_MemoryBaseAddr = (vu32) &ADC_ConvertedValue;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize = 10;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    /* Enable DMA Channel1 */
    DMA_Cmd(DMA1_Channel1, ENABLE);
    /* ADCx Configuration (ADC1CLK = 14 MHz) -----------------------------------*/
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel = 11;
    ADC_Init(ADC1, &ADC_InitStructure);
    /* ADCx Regular Channel_0-9 Configuration */
    ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_1Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_7Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_13Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_28Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_41Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 6, ADC_SampleTime_55Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 7, ADC_SampleTime_71Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 8, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 9, ADC_SampleTime_1Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 10, ADC_SampleTime_7Cycles5);
    // ADC1 configuration (vref)
    ADC_RegularChannelConfig(ADC1, ADC_Channel_17, 12, ADC_SampleTime_239Cycles5);
    /* Enable ADCx's DMA interface */
    ADC_DMACmd(ADC1, ENABLE);
    /* Enable ADCx */
    ADC_Cmd(ADC1, ENABLE);
    ADC_TempSensorVrefintCmd(ENABLE);
    /* Start ADC1 Software Conversion */
    ADC_SoftwareStartConvCmd(ADC1, ENABLE);
    while(1)
    My problem is only the first element of ADC_ConvertedValue[10] is updated. Could any of you point me what is missing/wrong with my code? Thanks in advance!
    Best Regards,
    Alex
    janvi
    seems wrong becouse destination address needs increment
    Further, I cannot see any reason, why the STM Examples always redefine
    their own headers inside main.c
    Instead of
    try:
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&ADC1->DR;
    [ This message was edited by: Janvi on 05-11-2009 10:49 ]
    aeolia_amha
    When I use uint32_t, there is an error saying that it is undefined
    alexlu.29
    alexlu.29Author
    Thanks for your help! It works fine.
    Best Regards,
    Alex
