SARTHAK KELAPURE
Dec 29, 2017 12:54 PM UTC
MQTT using STM32L0
Posted on December 29, 2017 at 13:54
Hello everyone, I am trying to use MQTT protocol on my STM32 board with SIM7000 as slave. if anyone had worked in such fashion, please can you share code snippets or library file used?? Is there any generalized library file for STM32?
Thank you
#stm32 #stm32l0 #stm32l0-stm32l0-discovery #mqtt
Andrew Neil
Andrew NeilBest answer
Dec 29, 2017 1:45 PM UTC
Posted on December 29, 2017 at 14:45
Like other internet protocols, MQTT is entirely independent of the underlying hardware.
So just try googling something like, 'MQTT microcontroller client'
Andrew Neil
francis kumar
Feb 23, 2018 9:29 AM UTC
Posted on February 23, 2018 at 09:29
I am also looking the same mqtt microcontroller client support in any ST series.
rgds
Andrew Neil
Feb 23, 2018 9:46 AM UTC
Posted on February 23, 2018 at 09:46
Again, it has nothing specifically to do with ST.
Andrew Neil
Feb 23, 2018 9:07 AM UTC
Posted on February 23, 2018 at 10:07
See:
https://community.st.com/0D70X000006SsnWSAS
sne_123
Oct 7, 2020 8:48 AM UTC
@SARTHAK KELAPURE​ Hi , I am also trying to work on the same thing as you have mentioned. Can you guide me a little bit on this?
sne_123
Oct 7, 2020 9:15 AM UTC
I am also using Sim808 with Stm32F103 board. So for Mqtt to work on stm32, do I need to configure TCP/IP using sim808 and then use Paho mqtt library??
