Missing FMC description in H5 Reference manual
Both in the manual and in CubeMX, it is shown that my microcontroller, has the ability to configure the FMC, for an asynchronous muxed PSRAM interface.
However, in the manual I can only find the timing description for the asynchronous NOR Flash and for synchronous NOR/PSRAM.
Am I missing something here, or is it missing in the manual itself?
Hello @Giorgi_Kvernadze and welcome to the Community,
The Asynchronous multiplexed PSRAM/NOR timings tables are described in the STM32H5 datasheets.
You can check the timings Table of Asynchronous multiplexed PSRAM/NOR, in the STM32H562xx and STM32H563x datasheet
I had something like this more in mind.
Hi @Giorgi_Kvernadze ,
Your request has been escalated through internal ticket number: 223546 to update the reference manual in the coming release.
Thank you for your contribution.
(PS: Ticket number: 223546 is only for reference and not available outside of ST).
Andrew Neil
welcome to the forum
Please see How to write your question to maximize your chances to find a solution for best results.
In particular, you didn't say which microcontroller, exactly, is "your microcontroller" - thus which particular Reference Manual you are referring to.
