Microcontroller stops working when I slow down the clock - Where do I even begin to debug this?
Posted on July 11, 2016 at 18:11
I am working with the STM32F405 microcntroller and in main() I have the following loop:
while
(TRUE)
UART_TransmitNullTerminatedString((uint8_t*)
''\r\nMicrocontroller alive ''
I run this firmware on 2 different PCB:s and it's working fine on PCB #1, but on PCB #2 it hangs after 3-4 seconds. Now, it would be easy to conclude that PCB #2is broken, but the strange thing is that PCB #2starts working fine if I run the microcontroller
faster. I use the following code to switch clock frequency:
void
ClockSwitch(ClockFreqType clockFreq)
// The code below was taken from HAL_RCC_DeInit() in file stm32f4xx_hal_rcc_ex.c
/* Set HSION bit */
SET_BIT(RCC->CR, RCC_CR_HSION | RCC_CR_HSITRIM_4);
/* Reset CFGR register */
CLEAR_REG(RCC->CFGR);
/* Reset HSEON, CSSON, PLLON, PLLI2S */
CLEAR_BIT(RCC->CR, RCC_CR_HSEON | RCC_CR_CSSON | RCC_CR_PLLON| RCC_CR_PLLI2SON);
/* Reset PLLCFGR register */
CLEAR_REG(RCC->PLLCFGR);
SET_BIT(RCC->PLLCFGR, RCC_PLLCFGR_PLLM_4 | RCC_PLLCFGR_PLLN_6 | RCC_PLLCFGR_PLLN_7 | RCC_PLLCFGR_PLLQ_2);
/* Reset PLLI2SCFGR register */
CLEAR_REG(RCC->PLLI2SCFGR);
SET_BIT(RCC->PLLI2SCFGR, RCC_PLLI2SCFGR_PLLI2SN_6 | RCC_PLLI2SCFGR_PLLI2SN_7 | RCC_PLLI2SCFGR_PLLI2SR_1);
/* Reset HSEBYP bit */
CLEAR_BIT(RCC->CR, RCC_CR_HSEBYP);
/* Disable all interrupts */
RCC->CIR = 0x00000000;
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
// First, switch to HSI to bypass the PLL
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7);
// The code below was generated with STM32CubeMX
switch
(clockFreq)
case
CLOCK_FREQ_1_MHz:
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = 16;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV16;
break
case
CLOCK_FREQ_2_MHz:
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV8;
break
case
CLOCK_FREQ_4_MHz:
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV4;
break
case
CLOCK_FREQ_8_MHz:
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV2;
break
case
CLOCK_FREQ_16_MHz:
break
case
CLOCK_FREQ_32_MHz:
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = 8;
RCC_OscInitStruct.PLL.PLLN = 64;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 4;
break
case
CLOCK_FREQ_64_MHz:
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
break
case
CLOCK_FREQ_128_MHz:
RCC_OscInitStruct.PLL.PLLN = 128;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
break
default
break
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, getNumWaitStates(clockFreq));
SystemCoreClockUpdate();
At 8 MHz PCB #1 is working fine, but PCB #2 hangs after about 3-4 seconds. If I instead run at 16 MHz or faster, then both PCB:s work fine. Does anybody have any suggestions how I can tackle this problem? Are there any status registers I should pay attention to? I'm running off a power supply and power consumption doesn't seem to be an issue (it's not drawing too much current and, surprisingly, the current consumption doesn't go down after PCB #2 hangs).
