MemoryMapped for w25q256 Octo SPI for Touchgfx
  • July 23, 2023
  • 3 replies
  • 2528 views
Hi, I used to work with a stm32h743 that had a QSPI, but now I work with a stm32h723zgt6 that has a OSPI. I don't know if I should continue with the MX_OCTOSPI1_Init function to use it for Memory Mapped for w25q256 program I wrote for Touch GFX.To use it for Touch GFX widgets
ُThanks
Best answer by
Finally, I was able to get an answer. I will put the code at the end for those who need it
OSPI_RegularCmdTypeDef sCommand={0};
    OSPI_MemoryMappedTypeDef sMemMappedCfg={0};
    /* Enable Memory-Mapped mode-------------------------------------------------- */
/* Common Commands*/
    sCommand.OperationType      = HAL_OSPI_OPTYPE_READ_CFG; /* Read Configuration (Memory-Mapped Mode) */
    sCommand.FlashId            = HAL_OSPI_FLASH_ID_1; /* Set The OCTO SPI Flash ID */
    sCommand.InstructionDtrMode = HAL_OSPI_INSTRUCTION_DTR_DISABLE; /* Disable Instruction DDR/DTR Mode */
    sCommand.AddressDtrMode      = HAL_OSPI_ADDRESS_DTR_DISABLE; /* Disable Address DDR/DTR Mode */
    sCommand.DataDtrMode = HAL_OSPI_DATA_DTR_DISABLE; /* Disable Data DDR/DTR Mode */
    sCommand.DQSMode            = HAL_OSPI_DQS_DISABLE; /* Disable Data Strobe */
    sCommand.SIOOMode          = HAL_OSPI_SIOO_INST_EVERY_CMD; /* SIOO Mode: Send instruction on every transaction */
    sCommand.AlternateBytesMode = HAL_OSPI_ALTERNATE_BYTES_NONE; /* Disable Alternate Bytes Mode */
    sCommand.AlternateBytes = HAL_OSPI_ALTERNATE_BYTES_NONE; /* Alternate Bytes = 0 */
    sCommand.AlternateBytesSize = HAL_OSPI_ALTERNATE_BYTES_NONE; /* Alternate Bytes Size = 0 */
    sCommand.AlternateBytesDtrMode = HAL_OSPI_ALTERNATE_BYTES_DTR_DISABLE; /* Disable Alternate Bytes DDR/DTR Mode */
    sCommand.InstructionMode    = HAL_OSPI_INSTRUCTION_1_LINE; /* Instruction on a single line */
    sCommand.InstructionSize    = HAL_OSPI_INSTRUCTION_8_BITS; /* 8-bit Instruction */
    sCommand.AddressSize = HAL_OSPI_ADDRESS_32_BITS; /* 24-bit Address */
    /* Instruction */
    sCommand.Instruction = 0xEC; /* What We Do? */
    /* Address */
    sCommand.AddressMode        = HAL_OSPI_ADDRESS_4_LINES; /* Define Address Lines: Address On Four Lines */
    sCommand.Address = 0; /* Byte Address */
    /* Data */
    sCommand.DataMode          = HAL_OSPI_DATA_4_LINES; /* Define Data Lines: Data On Four Lines */
    sCommand.DummyCycles        = 6; /* Bytes Send With No Data */
    sCommand.NbData            = 0; /* Bytes Send With Data */
    HAL_OSPI_Command(&hospi1, &sCommand, HAL_OSPI_TIMEOUT_DEFAULT_VALUE);
    /* Initialize the program command */
    sCommand.OperationType      = HAL_OSPI_OPTYPE_WRITE_CFG; /* Write Configuration (Memory-Mapped Mode)) */
    /* Instruction */
    /* Address */
    sCommand.AddressMode        = HAL_OSPI_ADDRESS_1_LINE; /* Define Address Lines: Address On a Single Line */
    /* Data */
    /* Initialize Memory Mapped Command */
    sMemMappedCfg.TimeOutActivation = HAL_OSPI_TIMEOUT_COUNTER_DISABLE; /* Timeout counter disabled, nCS remains active */
    HAL_OSPI_MemoryMapped(&hospi1, &sMemMappedCfg);
July 24, 2023
Hello again, I used to use the following code for Quad SPI and w25q256 and it worked perfectly, but now I don't know what code I should write for Octa SPI, please help me, I really need it
  QSPI_CommandTypeDef      s_command;
  QSPI_MemoryMappedTypeDef s_mem_mapped_cfg;
  /* Configure the command for the read instruction */
  s_command.InstructionMode   = QSPI_INSTRUCTION_1_LINE;
  s_command.Instruction       = 0xEC;//0xEC;
  s_command.AddressMode       = QSPI_ADDRESS_4_LINES;
  s_command.AddressSize       = QSPI_ADDRESS_32_BITS;
  s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
  s_command.DataMode          = QSPI_DATA_4_LINES;
  s_command.DummyCycles       = 6;
  s_command.DdrMode           = QSPI_DDR_MODE_DISABLE;
  s_command.DdrHoldHalfCycle  = QSPI_DDR_HHC_ANALOG_DELAY;
  s_command.SIOOMode          = QSPI_SIOO_INST_EVERY_CMD;
  /* Configure the memory mapped mode */
  s_mem_mapped_cfg.TimeOutActivation = QSPI_TIMEOUT_COUNTER_DISABLE;
  s_mem_mapped_cfg.TimeOutPeriod     = 0;
  HAL_QSPI_MemoryMapped(&hqspi, &s_command, &s_mem_mapped_cfg);
  HAL_NVIC_DisableIRQ(QUADSPI_IRQn);
July 25, 2023
Hi, do you have even one example ready for me to look at? So no one has worked with this part yet?
Best answer
July 25, 2023
    /* Instruction */
    /* Address */
    /* Data */
    /* Instruction */
    /* Address */
    /* Data */
