lorenzo meneghello_2
May 21, 2018 9:14 AM UTC
Memory Protection
Posted on May 21, 2018 at 11:14
Hi all,
I've read the entire reference manual about Memory protection, my question is:
If I set the protection level 1, and I wanted to change it 0 my Main Flash will be erased...
There's a way to avoid this? Because if I have the last page with personal data, I will lose them...
Thanks.
Lorenzo.
    Nesrine M_O
    May 21, 2018 9:44 AM UTC
    Posted on May 21, 2018 at 11:44
    Hi
    lorenzo.meneghello
    The main Flash memory and backup SRAM are erased when the RDP changes from level 1 to 0.
    You may protect your personal data usingThe PCROP : is a read and write protection of an IP code in Flash memory. It prevents proprietary code from possible modification or readout by the end-user code, debugger tools or RAM Trojan code.
    For more details about PCROB, I recommend you to have a look to
    http://www.st.com/en/embedded-software/x-cube-pcrop.html
    -Nesrine-
    May 21, 2018 12:13 PM UTC
    Posted on May 21, 2018 at 12:13
    I'm using the STM32F0 family, it's also possible ?
    Nesrine M_O
    May 21, 2018 12:23 PM UTC
    Posted on May 21, 2018 at 12:23
    Hi
    lorenzo.meneghello
    For the STM32F0 family , you may use the write protection: is used to protect the content of specified sectors against code update or erase. This protectionis implemented with a granularity of one sector.
    -Nesrine-
    Tilen MAJERLE
    May 22, 2018 7:55 AM UTC
    Posted on May 22, 2018 at 09:55
    Dear
    lorenzo.meneghello
    if you use custom bootloader, then you do not need to change RDP from level 1 to level 0 to be able to update firmware. But you have to write your own bootloader which is capable of SW update.
    In case of changing from level 1 to level 0, you will loose your data.
    Best regards,
    Tilen
    T J
    Senior III
    May 22, 2018 1:17 PM UTC
    Posted on May 22, 2018 at 15:17
    for a very small amount of data, I used the DS3232, for my RTC and 256bytes of User data.
    https://www.digikey.com/product-detail/en/maxim-integrated/DS3232SN-T-R/DS3232SN-T-RTR-ND/1197581
    or a SPI flash chip of course.
    the other solution is to never update.  like your microwave oven.
