jdmallett
Aug 23, 2008 5:40 AM UTC
Memory check
Posted on August 23, 2008 at 07:40
Memory check
    lanchon
    May 17, 2011 10:42 AM UTC
    Posted on May 17, 2011 at 12:42
    if you need to integrate checksums of your images into the build process you could check out ''srecord'' (it's GPL).
    jdmallett
    jdmallettAuthor
    Does anyone have any experience or code to perform a flash memory check (CRC etc)? I am using the Ride7 compiler. I do have the STM32 Self Test library but they are geared towards the Keil or IAR compiler.
    Thanks in advance!
    James
