arunease
Nov 25, 2015 1:32 PM UTC
memory calculation
Posted on November 25, 2015 at 14:32
anyone describe whats the below lines means.
'' memory device containing 64Mbit Pseudo Static Random Access
Memory using a self-refresh DRAM array organized as 4M words by 16 bits.''
    Nov 25, 2015 2:20 PM UTC
    Posted on November 25, 2015 at 15:20
    Do you understand the difference between dynamic and static memory? ie charge held by a capacitor vs logic state held by several transistors.
    4 x 16 = 64
    The memory is arranged so each storage location holds 16 bits, there are 4 million (4194304) locations, which are uniquely addressable, in random order.
    The device is dynamic, pretending to be a static device, it refreshes (recharges) the storage cell capacitors in the background, with no interaction from the external system.
