Measure PWM Input Frequency from 0.016 Hz to 250 Hz
Greetings Everybody,
I want to ready PWM Input Frequency from 0.016 Hz to 250 Hz. I tried a bit with PWM Input Capture and i can read up to 11 Hz . Is it possible to ready frequencies lower than this ?
May be i might be doing some thing wrong in setting the timer clock. I have used Timer 2 for this purpose..
Any further guidance will be of great help..
Thanks.
