MCU with IO bandwidth of 150Mhz or more
Hi All,
He have an application that requires fast IO's switching. More specifically, we have a 16bit 200Msps parallel DAC and we are targeting to load a waveform from either flash memory or external memory and output the bits for the DAC. Using an FPGA is of course an option but it will be convenient to have an MCU for this application.
My question is
- Any MCU that can have an IO bandwidth of 150Mhz? If negative what would be he closest one? I've seen people running STM32F4 boards at 162Mhz reaching a BW of 30Mhz using minimum instructions and BSSR instructions.
