Öyild.1
Aug 23, 2021 7:43 AM UTC
MCP2515 Module Library
I would like to use MCP2515 module which can be found here. Is there any tested official or nonoffical library that I can use with stm32f429-disco developer kit? Thanks inadvanced.
Aug 23, 2021 10:25 PM UTC
"stm32 mcp2515" returns quite a few results.
https://github.com/thumptech/STM32-MCP2515
Öyild.1
Öyild.1Author
Aug 24, 2021 7:36 AM UTC
I have tried that one but it has not completed. There is missing files like "can.h".
SaidErsoy
Mar 21, 2022 11:23 AM UTC
Hi, i have same issue you had. Did you solve it or find another file?
Mar 21, 2022 1:33 PM UTC
FPicc.1
Feb 24, 2023 7:49 PM UTC
Hi, I'm having the same issue, have you found a solution yet? I'm using a STM32WL55 board, and using this library: https://github.com/eziya/STM32_SPI_MCP2515
Feb 24, 2023 8:59 PM UTC
That it can't find "can.h", or something else?
FPicc.1
Feb 24, 2023 9:26 PM UTC
Actually the can.h is on the reference that the github above used, but I didn't try with this code.
I too am trying to comunicate the MCP2515 with the STM, with the library that I sent before​, but it isn't working for my case. I already spoke to the owner of the code and it works fine for the stm32f1xx. I made the alterations for the wlxx, but I still can't receive any data.
