Arjun Oberai
Jan 18, 2018 5:44 AM UTC
Maximum Timeout for Window Watchdog(WWDG)
Posted on January 18, 2018 at 06:44
I have a question regarding the WWDG in STM32F103RB.
  • What can be the maximum timeout using the WWDG or even better question will be what will be the optimum value of the APB1 clock period(ms).
I know the Maximum value of the APB1 clock can be 36 MHz. I suppose using the least value of the APB1 will give us the max timeout, but I am not able to figure what can it be.
#watchdog #wwdg #stm32
Danish1
Lead III
Jan 18, 2018 9:05 AM UTC
Posted on January 18, 2018 at 10:05
From the reference manual, section on Reset and Clock-control
APB1 frequency is determined by a pre-scaler/divider from AHB frequency; the divider can be 1, 2, 4, 8 or 16.
AHB frequency is determined by a pre-scaler/divider from SYSCLK; the divider can be 1, 2, 4, 8, 16, 64, 128, 256 or 512.
So how slow APB1 can be depends how slow you can run your processor and AHB bus.
Personally, I wouldn't normally run the processor slower than 8 MHz because that's what it starts at.
And from 8 MHz / 512 / 16 = 976 Hz approx.
Hope this helps,
Danish
Arjun Oberai
Jan 18, 2018 12:00 PM UTC
Posted on January 18, 2018 at 12:00
Thank You Danish, that was a comprehensive reply that clears my doubt.
Cheers,
Arjun Oberai
