Maximum analog output voltage from STM32H723ZG
Hi, which is the maximum analog output voltage from the STM32H723ZG? In the datasheet I saw that there are two Op-Amp inside the MCU with gain from 2 to 16. How can I use this Op-Amp? I have to do something about the hardware or I have just to write some code?
