Mapping System clock on GPIO
Posted on November 15, 2013 at 14:06
Hi all,
I'm working with STM32F3DISCOVERY.I'm trying to map the system clk on a GPIO to view it with an oscilloscope.In the following datasheethttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00058181.pdf
on page 39 I've found the signal SWCLK-JTCK that should be the system clock, but I didn't find any information on this signal. Do you know this signal?Thanks and regards #stm32f3discovery #swclk-jtck
