jaroslaw23
LSI as RTC clock
  • December 15, 2011
  • 3 replies
  • 906 views
Posted on December 15, 2011 at 11:24
Hi ,
Is it possible to run RTC with 40khz LSI when power is off and CPU works on battery only?
#rtc #lsi
domen23
Posted on December 15, 2011 at 12:50
7.2.8 RTC clock
... says LS
E
is in backup domain, and other clocks are not.
jaroslaw23
Posted on December 15, 2011 at 15:11
Thanks, I miss it in manual.
balmukund66
Posted on December 19, 2011 at 06:51
It is not Possible.As LSI uses internal RC Oscilator to generate clock.For this purpose Vcc is required.VBAT gives supply to only RTC block.
